5600 with drive problems
/ 5600 with drive problems #21
OUCH !! That is an expensive break down. Any guess from mechanic as to what tends to cause such a failure? Stress or contamination or ?? Is this motor unique to the TC or used in other Bobcats?
Hope you get back up & running pretty quick.
Got it running tonight pretty fast fix after you spend the money... I had three tech's in their office today at Bobcat and they had never seen anything like it. The Comer motors where a joint project with Bobcat when they developed the Toolcat if you do a search with comer and toolcat the info will come up...By the way that is the only Bobcat machine that uses Comer that I know of. The other failures with the bad drive motors with the b and c machines where associated with the brass sleeves around the pistons wearing badly, most of them weared bad enough that it would plug the hydro system filter and contaminate the whole system, I was lucky enough that my failure was contained in the motor and the case drain system and filter (by the battery) it did its job.
/ 5600 with drive problems #23
I believe some of the mini escavators use Comer as well.
What model Toolcat do you have?
dsb
Its 2004 and I believe it to be a A-Model..Not sure Bobcat hasn't told me the model just the year and manufacture date.
/ 5600 with drive problems #25
I thought I would post (what I'm hoping is) a final update to the 50-56 error code. During the last series of storms the intermittent problem with the TC refusing to allow the transmission to engage was increasing in frequency. At one point the Driver of that unit radioed that it had quit on him 5 times in one driveway. It was no longer functioning properly even at operating temps, which had proven to temporarily solve the issue in previous storms.
Out of desperation I finally loaded the unit on a trailer and hauled it the two hours to the dealer. I arrived just before closing and the TC would not allow me to move it off the trailer. It took approximately 20 attempts (shutting off and restarting) to even back the TC off the trailer. I felt bad because the employees were waiting to go home and had to wait for me.
In the morning the Service Manager drove the TC around and could not get it to fail again! Finally, on the following day the Service Manager called and said he got it to fail and that the first thing they found when the laptop was hooked up was the diagnostics could not find the CPU! It appears that the problem intermittently resides in the Console CPU. The Service Manager ordered a new Console CPU and was told that they are on back order. Somehow, he found one and with overnight shipping, it arrived today! They are installing the new CPU and reprogramming it. They want to keep the TC an additional day to see if that is the only problem. I'm keeping my fingers crossed! Another storm due in on Sunday night! If there are any additional issues I will post them. Thank you to everyone that responded! I have tried to post all of the symptoms. I'm hoping that by posting all this it will save someone else all the time and frustration.
/ 5600 with drive problems #26
Man, I hope that's it! What a time of the year for problems...but thanks very much for the updates.
/ 5600 with drive problems #27
Well, The troublesome TC has been running since Sunday night with more snow predicted thru Friday and not one problem since the console CPU was replaced. It appears that the issue is finally over!
Thanks again for all the responses!
/ 5600 with drive problems #28
Does anybody know of this happening with the new TC's. I have just recieved on mine on Jan 10th 2008. It stopped while I was tramming it. It was still running, but would not move. I shut it down for 30 seconds and restarted it ran just fine. Have not had a problem since. The dealer wants to go over it but have not had a break in the weather. This worries me a little.
I'll be sure to mention your findings, thanks for all the info.
Just a pic of my TC with blower and rear box scraper/salter combo.
/ 5600 with drive problems #29
That is a nice looking setup. Where did you get the rear scraper?
What is tramming?
dsb
/ 5600 with drive problems #30
Tramming is a term used in mining for driving forward or backward usually in reference to a self-propelled machine.
Welcome to the forum Allan !! Had quite a bit of snow this season up in Ontario I hear.
That is a very nice set up you have. What brand/size blower? Hi-flo? Can you still tilt the bed up for engine access with blade & salter on the back? Looks like you might if you removed the tailgate.
Hope to hear more from you....maybe even some action shots. Good Luck.
/ 5600 with drive problems #31
Hi
The blower is bobcat, with hi-flow and is six feet. Yes I ended up removing the tailgate, you could get access, but afraid anybody working for me might have crushed something forgetting about it. I just replaced it with one of those bungee mesh type tailgates for the winter, it allowed for better visibity of the rear scraper anyway.
/ 5600 with drive problems #32
Hi
This rear unit was purchased through a company called snowman snowplows and it was around $5800.00 canadian. Their website is Home Page - Snowman Snowplow
Learned the hard way that this unit needed some added framing support which bobcat took care of free of charge. Only later to learn that the rear hydraulic downpressure is a bit much for this unit. The bobcat dealer is now going to install a 1000 p.s.i. release valve, but I'm going to see if they can install a adjustable release valve with accumulator. I'm told from a mechanic at work(oh yeah I do work in a salt mine as well) that this will take some adjusting to get just right the way I like it, but once set it should just float with the pressure that you choose. Think I'm going to need some luck.
/ 5600 with drive problems #33
Allan, Sounds like between your Bobcat dealer, mechanics at the mine, and yourself, that you have a pretty good handle on the situation. The idea of an adjustable relief and accumulator for the rear sounds good.....I like "adjustable", although not always in the hands of employees.
Once again, really nice set-up.....we would all be interested to hear periodic reports on how well it all works. Start a new thread, as this one has been hyjacked too much already.
Rip
(10) 36' HEAVY DUTY INSULATED PANELS (A62131)
(10) 36' HEAVY...
GAS BOY DIESEL FUEL PUMP (A62131)
GAS BOY DIESEL...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
Auger Bit (A61567)
Auger Bit (A61567)
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
