Backhoe 555A Engine Sleeved or not?
   / 555A Engine Sleeved or not? #1
housemasters
Can someone tell me if a 201 diesel engine in a 555A is sleeved?
Mine has a hole somewhere between the water jacket and the crankcase.
I bought this used and I see what I think are flanges at the top of the cylinders. Does a factory (un-rebuilt) engine show what look like flanges?
   / 555A Engine Sleeved or not? #4
Those are probably marks made by the fire rings in the head gasket.
   / 555A Engine Sleeved or not? #5
I've got a service manual we are just getting ready to put on e-bay at the store, I'll check it in the morning but not to many ford engines run sleeves.
Art send me a link to your store please.
   / 555A Engine Sleeved or not? #7
www.whitesfarmsupply.com but normally the quickest way to me is whitefarm@aol.com
I did check the manual sold yesterday, your block is not sleeved.
You can have a machine shop cut and install a dry sleeve for you to fix your issue.
   / 555A Engine Sleeved or not? #8
G'day just be absolutely sure you are on the right track before you sleeve it as these engines have a bad habit of cracking from the oil galleries into the water jackets, i have seen many attempts at repairing them and have yet to see one succeed, sorry to tell you this but it usually means a new block
Jon
I got a remanufactured block on its way.
2014 JCB 930 (A53317)
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
