5530 vs 6530 - 4WD
   / 5530 vs 6530 - 4WD #1
vox
Texas, by God!
mahindra?
Hi All from Texas!
Long time lurker, first time poster.
Ready to buy, just trying to make the right decision in terms of model and tranny.
Looking at the 5530 and the 6530. Not sure if we should go shuttle/PST/HST. Interested in any comments on this front.
Duty Specs:
- Small Farm / Ranch (less than 200 acres - 50% is heavily timbered)
- shredding, will purchase the 10' pull shredder from mahindra (not 3pt)
- front end loader for earth, tree limbs and hay
- box blade for general road maintenance and erosion control
Questions for the team:
1. Too big? Too small?
2. Other models I should look at instead?
3. What type of rubber should I put on it? (ag tires?)
4. Is the grapple worth the money? We have a lot of dead-fall around after storms and what-not.
Thanks for everyone's thoughts.
vox
   / 5530 vs 6530 - 4WD #2
If you're gonna pull a 10ft cutter you should get the biggest you can afford...the 6530 will do fine...I know there's a bunch of differing opinions here, but I'd go for the gear/shuttle shift. since you're on a ranch/farm, I'd also go for the R1 Ag tires. Of course I'm a tad biased as I was raised on a farm...and now have a 6000 4WD, shuttle/ag tires...good luck. BobG in VA
Bob...appreciate'ya.
Are the ag tires good-to-go in mud? We have a good amount of acreage that gets water logged on a regular basis.
Appreciate your time...
   / 5530 vs 6530 - 4WD #4
If you're dealing with mud, R1 (ag) tires are your only choice. Well, those and tracks I suppose. I love my hst, but that's just my opinion.
Noted.
Thanks much.
   / 5530 vs 6530 - 4WD #6
Is the grapple worth the money? It's worth it's weight in gold. If you do nothing else, get the grapple! In fact, there is very little need for a bucket after having a grapple for any type of woods work and debris cleanup.
   / 5530 vs 6530 - 4WD #7
Avoid buying a grapple ONLY if you like to climb on and off your tractor endlessly.:wink:
,,,, I recommend the smallest heavy duty one you can find. ... Also a Bobcat tilt tatch to live on the loader. The increased manipulation capability is worth the 300# tax.
larry
   / 5530 vs 6530 - 4WD #8
Hi All from Texas!
Duty Specs:
vox
Get as much hp as you can afford--200 acres is a lot of land.
Be sure you get the skid steer quick attach option for your FEL.
Get double rear hydraulic remotes--triple is better. Mine is a dealer-designed rig that cost $700 (part of the deal when I bought the tractor new in 2008).
Ag tires for sure.
I added an expanded metal screen to the ROPS (use hose clamps to secure it--no drilling or welding on the ROPS, it's a safety feature that shouldn't be altered). Protects my backside when mowing with the brush hog.
Good luck.
Makes sense.
Thank You for the feedback.
   / 5530 vs 6530 - 4WD #10
Forgot a couple of things...Get your Rear R1 Ag tires "loaded"...especially if you have an FEL...keeps the rear end on the ground when you pick up a heavy load...now regarding "wet" stuff...just because you have 4WD you gotta remember that the only difference between 2WD and 4WD is can get get further into the swamp with 4WD before you get stuck.....(grin).. Good luck...BobG in VA
   / 5530 vs 6530 - 4WD #11
If you are considering the 5530/6530, you have no HST or PST option, just a clutch type shuttle. The 35 series has the HST or PST options, but they are smaller.
That clutch type shuttle works fine, unless you have a bunch of close quarters type of back and forth loader work...in that instance you get tired of clutching pretty fast. For the average farm duty, a clutch type shuttle is simple and strong.
   / 5530 vs 6530 - 4WD #12
Some may tire of it,but I have no problem with clutching my shuttle even in tight quarters..Of course I was used to a lot of older tractors(hit clutch..find reverse... clutch... find first etc..all while manipulating the fel..and (hand throttle) with out a foot throttle to make it easier)While I don't have the 55 or 65 I did buy the 4530,which has done anything I have asked it to do and more. Has done more than a lot of higher horse power tractors that I have owned over the year's. Primary uses for mine is fel work,brush hogging ,drive maintenance ,haying,moving round bales, basically an all around farm tractor.I personally chose the 30 series because I wanted a tractor..(no digs at anyone else's choice )I didn't need a cup holder ,or all the newest ergonomic amenities..I wanted a heavy, well built,ground engaging tractor that would do what I required of it. The few thing's that bugged me ? I changed them...for instance..I didn't like the position of the shuttle shift(I had to reach to far to shift it comfortably from forward to reverse. I fabbed a new one, to the reach I wanted, and kept the old factory one for later. All in all I have not been disappointed..just my :2cents:
Regard's
Sean
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
2023 RTVXG-850 SideKick (A61306)
2023 RTVXG-850...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
