Oil & Fuel 5525 Fuel Gauge - Hosed up
   / 5525 Fuel Gauge - Hosed up #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
Anybody else have issues with their fuel gauge. Was reading 1/4 tank so I topped it off. It now reads 3/4 tank until I start the tractor then it reads 1/2. Maybe some bouncing around in the a pasture will make it work right. I am thinking bad sender or a bad ground.
Ideas?
D.
   / 5525 Fuel Gauge - Hosed up #2
I think you are on the right track Darin. Lots of people have had problems with these fuel guages and I expected to have them also. So far mine is accurate though that may change.:(
   / 5525 Fuel Gauge - Hosed up #3
Had an issue with the guage on a 5205. Fuel level was fluctuating and while checking it out I noticed a leak around the sending unit. Wound up replacing the broken sending unit. Replacing fixed the leak and the guage worked fine. My only guess was a limb popped up and broke it.
RYOBI 18V ELECTRIC 13" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
TEYME 2000 E0L0 GTE10 LOT IDENTIFIER 213 (A53084)
TEYME 2000 E0L0...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
CONTACT INFO LOT IDENTIFIER 6 (A53084)
CONTACT INFO LOT...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
