5525 2nd and 3rd valve hard to get lines into the valves
   / 5525 2nd and 3rd valve hard to get lines into the valves #1
cowboy11
homewood
5420/5525 john deer 6610 ford 3910 ford
5525 john deere cab model when cutting hay with krone conditioner/cutter very difficult to hook lines into vlaves sometimes take as much as 30 minutes
struggling to hook them up . once they connect all works well. it also is very difficult to unhook these lines works with no problems on 5420 deere anyone
experience this . :confused2:http://www.tractorbynet.com/forums/images/smilies/new/confused2.gif
   / 5525 2nd and 3rd valve hard to get lines into the valves #2
If this is the only implement you have issues with, change out the couplers on the implement.
Problems going in May be pressure buildup in the lines. Push the coupler face against a flat surface until it depresses the ball. If it is pressure build up, oil will shoot out. It should connect easy then. To disconnect, try shutting 5420 off and moving SCV lever to remove line pressure and then push in and yank back.
thanks I will give it a try it has been a b---- tries your patience :cool2:
   / 5525 2nd and 3rd valve hard to get lines into the valves #4
I wonder if coupler attachment problem was why JD changed the type of breakaways on a 5525.
RoGator RG1100C (A53473)
RoGator RG1100C...
2013 Bandit 200XP Towable Brush Chipper (A51691)
2013 Bandit 200XP...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2007 Ford F-350 9FT Stakebody Flatbed Truck (A51691)
2007 Ford F-350...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
