5520, how wide?
/ 5520, how wide? #1
mw243270
Can one of you 5520 owners tell me how wide this tractor is at it's widest point? I have a trailer that's 84 inches inside the fenders and need to know if it will fit.
thanks!
Mark
/ 5520, how wide? #2
thanks!
Mark
The answer to your question depends entirely on the tire and wheel options and track setting on the particular tractor you intend on hauling. If your 84" wide trailer is rated for 7000 lbs as mine is, a 5520 is probably going to overload it weight wise.
/ 5520, how wide? #3
thanks!
Mark
How long is the trailer?
How much weight is it rated to haul?
What do you toe it with?
/ 5520, how wide?
trailer is 24' and rated 14000lb, pulling with 1ton dually. Any idea what the range of width's might be?
/ 5520, how wide? #5
The range would be from the possible to not gonna happen. Sounds kinda flip, but that's the truth. I used to run a 5520 4x4 with 16.9x30 rears. Before I changed the tread width, it would have fit your trailer. After, it would not.
/ 5520, how wide? #6
It is going to be very tight. My 5420 (identical tractor except for the turbo is missing) measures in at 80" front and rear with 16.9-30" bias ply on the rear and 11.2-24" on the front.
/ 5520, how wide? #8
thanks!
Mark
Depends on the wheel tire config.
D.
/ 5520, how wide? #9
I may be wrong but I think its possible to configure it down to about 74-76"???
/ 5520, how wide? #11
FYI, depending on how you have your 5520 balasted, you might be right on the limit of the trailer. My 5420 MFD ISO station with FEL, loaded rears, dual wheel weights and front weight bracket weighs in at 10,200.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 COTTRELL CAR HAULER (A67714)
2015 COTTRELL CAR...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
