5510 with dead odometer
/ 5510 with dead odometer #1
masalser
Snohomish County, Washington
John Deere 5510, Kubota HST 3010, ASV RC100 tracked skidsteer, Bobcat 435 excavator, Howard Price 15' finish mower, Kubota ZD331 mower, Woodmizer LT40 super hydraulic sawmill
I have a 5510 open cab tractor with about 1500 hours on it, and in the last fifty or so hours the LCD odometer died. The only other thing not working is the turn signals. I checked all of the fuses and found no blown fuses. Any ideas on where the problem might be? Is there perhaps a fusible link that I should be looking at, or am I probably looking at an instrument cluster replacement? Thanks for any help
/ 5510 with dead odometer #2
I would check the wires coming from the ignition switch first. In my experience, open cab tractors tend to have a fair bit of trouble with bad connections/corrosion there.
-Phillip
/ 5510 with dead odometer #3
Not sure if it is the same on the 10 series but on 00 ones, the wiring harness split at the dash and went to the turn signals and the dash cluster. Check to see if the dash cluster connect came loose.
Mistyridgefarm, thanks for the suggestion. I'll take a look.
/ 5510 with dead odometer #5
Are you talking about the hour meter? Our 5420 open tractor's is dead too. Only has around 450 hours on it but it is 10 years old now. I haven't had any luck in another thread to find out the culprit.
Come to think about it, the cold start sensor at the thermostat had to be unplugged when it kept blowing the fuse when the key was turned on. I wonder if that could be a clue? This happened about the same time.
/ 5510 with dead odometer #6
Check the dash ground connection.
3147 (A63117)
3147 (A63117)
1997 Ford Expedition 4X4 SUV (A66738)
1997 Ford...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
1994 GREAT DANE 48' T/A DRY VAN TRAILER (A67714)
1994 GREAT DANE...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
