5510 wiring diagram
/ 5510 wiring diagram #1
kavik
Any one have a 5510 (no cab) wiring diagram, it's not on the online manual.
I have a bunch of connections under the tractor (mostly lights) that were pulled apart by brush and I am chasing a starting problem - I have to jump the starter with a wire from the solenoid to the starter. I am guessing a ground/relay/neutral switch issue but need a wiring diagram to try and troubleshoot.
chris1@west.net
/ 5510 wiring diagram #2
I can't help with the diagram, but the FSM (factory service manual) on CD is only $120 from JD, you could save that many times over if you had it.
5510 Manuals
