5510 or 6210
/ 5510 or 6210
Bird-no he didn't. He didn't drive the tractor so he might just think it's not going to work as good as a gear transmission would. Have you had any problems with your HST transmission?
ejb-my brother was up to the Deere dealer today and he sat on both the 5310 and 5410. The 5410 was much better. He said it looked like a much stronger tractor and I told him how much you like yours. That got him thinking about the loader. He's thinking about the open station but he would like the heat and a/c for winter and summer haying. I told him that I could move the bulk of the snow at his place because he is going to be mowing my lawn. He thought that was a good idea. can you get a canopy for the 5410? Would you recomend 4wd or 2wd? I know that if he gets a loader he would probably want 4wd, but since he's going to be using it for haying and driving on the road hauling hay wagons, 2wd would probably be better. He also looked at the skid steers and he deffinately wants the 5575. It's exactly the same size dimension wise, but it can lift more and has a larger engine.He's still looking at small tractors for lawn and garden duty.
This is not about tractors but in your edit profile area and then in basic f=profile is anyone having trouble getting their information to go through.?
/ 5510 or 6210
ejb- I forgot. The price for the 6310 4wd, cab, and loader is around $70,000. That's in Canadian currency too.
/ 5510 or 6210 #23
Vernon, I've never any kind of problem with either of my HST transmissions. I know there's a place for the other types, and some reasons for buying them, but I love the HST, especially if you're going to do much loader work, maneuvering forward and backward a lot, plus when mowing, I sometimes want to vary the speed and it's so easy to do with and HST. Anyway, I was just curious as to what someone would dislike about it. And I don't guess I've tried to edit my profile, other than the display preferences, and there was no problem with that going through.
Bird
/ 5510 or 6210 #24
Hi Vernon,
I had a problem with the demo HST (and so do many others) until someone carefully pointed out that it was not a accelerator pedal, that if you wanted more power you lifted up and more speed pressed down. Seemed absolutely against human nature, but if you train yourself to do this it seems to work really well. Kubota's HST is smoother.
I tried the JD5310 and JD5410 and liked both well. If he buys the 5310, be sure to get the oversize tires as Deere puts too small a tire on as standard.
I liked the loader on the M8200 and M9000 but settled on the smaller M6800SD in 4WD with Loader and quick attach bucket was $27,000 U.S. It only has a 6 ft bucket where the larger tractors have 7 ft buckets with 4 bar linkage loaders and hold a lot more. I can't stall the 6 ft bucket but did not try the 7 ft.
I found no fault with the John Deere 5310 or 5410 (except green paint seems to be a little more expensive). The 5410 is considerably longer wheelbase than either the 5310 or M6800. I like the Kubota cabs visibility and flat floors a little better than the Deere Cabs, but bought the ROPS model.
Good luck.
/ 5510 or 6210 #25
WoW! even in Canadian money, $70K is a lot of money...
I can't really recommend the 2wd versus 4wd for your brothers application cause I don't know much about his land and intended uses...if its not a lot of extra money, you can always leave the 4wd in 2wd right? My land tends to get very wet in the spring.t and there is no way I could get buy w/out 4wd, plus I have the loader so its a nobrainer for me.
/ 5510 or 6210
ejb-the $70K Canadian is about just under $50K American. There are hills and the land can get wet in my area too. About 43 acres of his land is wooded but I will be taking care of that part with my equipment. I think now that the 4wd would be the best choice, even if he doesn't use 4wd as much. He's still thinking loader and still can't decide to get ROPS or cab. The small tractor is still unknown to him. He doesn't think he needs the loader since he'll have the skid steer, but it might come in handy sometimes. One attachment he is thinking about getting is a posthole digger for his tractor. Do they work well?
I'm going to talk about my tractor for a minute too. Another perfect day of driving the 6310. I'm trying to get a good feel for it so I took my 920 hay mower and cut some hay. Even with the loader on it worked wonderful. I'd just like to say i am a proud owner of the JD 709 rotary cutter. I only had it one day at my farm but it cut so well I took a drive to my Deere dealer with my brother today and I bought it. You guys have been very helpful so far and I hope the advice never stops.
/ 5510 or 6210 #27
No experience with the post-hole attachment, but I have had my eye out for one as well. My biggest concern is that JD5410 may be too powerful for some posthole diggers...one thing I have found so far is that once you buy a tractor in this size, EVERTHING is more expensive for it...that is if you don't want to destroy it.
Glad to hear you are happy so far with your decisions...keep us posted.
/ 5510 or 6210 #28
Does a post hole digger work well? Yes. Of course, like all the other implements, there are light duty models and heavy duty models, shear pins and slip clutches, soft easy ground to drill into and hard rocky ground, so some of them work better than others and they work better in some kinds of soil than others. But it sure beats digging them by hand./w3tcompact/icons/wink.gif
Bird
/ 5510 or 6210 #29
ejb
The post hole diggers are only as powerful as the slip clutch lets them be. Many will handle this size tractor. The Danuser is probably the best known heavy duty model. I have broke the ears off some of the light duty ones. Interestingly, the biggest problem is usually not the digger at all, but the auger. A really heavy duty auger is essential for all but the best of soils. A little company in Texas called Bel Tec builds some of the heaviest duty augers and they build to fit most standard heavy duty model post hole diggers. Many so called heavy duty augers aren't. Some brands of diggers are NOT designed to be used at full PTO speed. Those with a shear pin will work just fine, it just a pain to hit rock and spend all of your time replacing shear pins. Conversely the slip clutches have to be serviced a couple of times during the year and work better if protected from the weather. Augers are used every day on over 100 HP tractors so you should have no problems finding one.
If you happen to have rocky soil there is an expensive solution that only works for 65 hp and up tractors that will drill postholes in chunk rock soil or solid rock.
<P ID="edit"><FONT SIZE=-1>Edited by wen on 6/30/00 12:26 PM.</FONT></P>
/ 5510 or 6210 #30
>>If you happen to have rocky soil.
My land is VERY rocky unfortunately...a neighbor of mine, about 15 miles away has similar problem and needed to put in a lot of fence posts (many thousands), to control a pretty big population of animals...he ended needed to use a jackhammer to get a lot of his posts in.
What is that other solution you were referring to?
/ 5510 or 6210 #31
The company is Belltec Industries, Inc at po Box 270 Belton TX 76513 (800)242-9410. It is a complete unit that mounts on a CAT II 3 point system and then locks it in place. It has two hydraulic cylinders that apply several thousand pounds of downforce to a carbide tipped auger. Need a heavy tractor. The system actually lets you get as close in to a fence or building as a standard auger. They will drill through either chunk rock or solid rock. You can get augers for T post size holes or larger ones. They are not cheap. The guy across the street bought one and I watched him using it. Made short work of an impossible task with most augers that would just jump around in the hole. He had it on a 65 HP Case Tractor. The auger is also turned by hydraulics, so you have to have two sets of external valves or take the bucket lines loose so you can drive the downpressure cylinders and the very powerful hydraulic motor on the auger.
I have considered getting one just to see how much business you can get drilling post holes in rocky areas.
/ 5510 or 6210
The soil here is really good soil for plowing and cultivating, so if I got a heavy duty posthole digger it would more than work. There is very little rock. Another day of using my 6310 and what a great day it was. hooked up to my log trailer to move some wood and it pulled the trailer much better than my 2355 used to. I'm going up to my deere dealer on monday to make the final purchase for 6310. I'll tell everything it has on monday after I get back.
/ 5510 or 6210 #33
Vernon,
The Danuser should work just fine for you. They have been in the business for many years and are well respected by everyone.
/ 5510 or 6210
What are the JD posthole diggers like? It was my brother looking for one and land pride makes a model that is rated up to 65 PTO hp I think. He want's to get one for his larger tractor he's going to buy.
ejb-what is your tractor like on the road? Does it have good speed? My brother has narrowed it down to either the 5410 4wd with the 541 loader and open station with the canopy or the same tractor with the cab. I think he's going to have quite a good tractor with or without the cab. My brother is also thinking about getting the 250 JD skid steer with the 12" tires. Have you heard anything about these new skid steers? I saw the 250 when I was up to buy my 709 bush hog and it looked like a good machine.
/ 5510 or 6210
I bought my tractor today, and did I ever get a good one. I get the 6310 4wd w/cab and 640SL loader. It has the 38" tires, 24F/24R PowerQuad w/left-hand power reverse transmission, 4 Deluxe SCV's, dual 540/1000 PTO rpm, front fenders, fuel tank bottom gaurd, 110-volt block heater, lighting enhancements and beacon light, AirComfort seat, AM/FM sterio. Aside from the regular bucket I got the pallet forks and round bale spear.
My brother went up to our DEERE dealer today with me and he checked out the 250 skid steer too. He liked it so much that he is getting a demo of it tomorrow.
/ 5510 or 6210 #36
vernon...congrats and enjoy it. Let us know how it performs for you.
/ 5510 or 6210
My brother just got his 250 skid steer today andd he has been using it to work on his buildings. He sais it works great. He also decided to get the 5410 4wd with the 541SL loader and the cab. He also got that delivered today. He thinks it is a great machine and he wants to thank you, ejb, for the advice on trying the 5310 and 5410. He's used it to move lumber around and feels that the 5310 wouldn't have had the horsepower he needs. He's also glad he got the 4wd because if he didn't he wouldn't have been able to move some of the lumber because the groungd is soft in places because it rained quite hard last night and some more this morning.
/ 5510 or 6210 #38
I am glad he is happy. There is, as your brother found out, a huge difference between the 5410 and the 5310. Glad he made the right decision and glad I could help.
/ 5510 or 6210
ejb. I forgot. I got the hooks mounted on the back of the bucket too. I bought a new bucket like the original too, so that if I bent the one with hooks I would still have a bood bucket I could use. My brother bought his 250 skid steer and 5410 today. He likes them alot. he got the pallet forks and round bale spear for both. He also got the high volume bucket for his skid steer. I know I just bought a new tractor but i drove the 250 aroud helping him build his new barns and I like it too. It would probably be better for cleaning out my cow barn. It would also be very handy in the woods I think. You could put the tracks on it and you shouldn't have any problems getting around. My brother is thinking about getting the 4600 4wd w/the gear transmission with the 460 loader. Can you use 541SL implements on the 460?
/ 5510 or 6210 #40
As far as using the 541 implements on the 460 loader, I am not to sure, but I bet your dealer would know.
As far as the 4600, it seems like a pretty nice machine, but if your brother bought a 5410, the 4600, although a tad smaller, seems like there would be an awful lot of overlap in capabilities between the two? In other words, there are probably only a few things that the 4600 could do that the 5410 couldn't do as well (except perhaps mowing), but if all you want to do is mow with the thing, you could probably get by with a smaller tractor.
Did you two guys win the lottery lately? Between the two of you it sounds like you have spent close to $100K, if not more, at your JD dealer???
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
New/Unused Electric 3-Wheeler (A65583)
New/Unused...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
Landhonor 10" Utility Blower Fan (A66408)
Landhonor 10"...
New/Unused Electric Winch (A65583)
New/Unused...
Club Car Emergency Cart (A64557)
Club Car Emergency...
