550 XP documentation
/ 550 XP documentation #1
R134a
Mahindra 2538
Does anyone have a disassembly guide they would like to share ? I want a heads up before the time comes for surgery. Thanks in advance.
/ 550 XP documentation #3
Have you used your 550XP much? How do you like it? I've had mine for a number of years and other than diagnosing a faulty spark plug that was causing me fits, it's been great for my yearly firewood cutting. My only gripe is that it seems to be a real miser on throwing bar oil. I cut a lot of standing dry oak and my bar turns purple pretty quick, even with the oil turned to max.
Replies to above...
Thanks for the WM link. My 550 is from 2014. It still works 100% for now. A little monster. I have heard some things I don't like, one of which is crank bearing failure on the chain side. I'm sure that plastic bearing will fail when I need it most. I will look at the WM to start a list of parts & special tools needed for the job.
I can go months without using the saw and then saw for days at a time. Hurricane Michael got me disgusted. Enough down trees for the next 200 years. I gave up.
The oiler is set so you should run out of fuel before chain oil. Your chain is dull and/or the oiler is clogged. I run full chisel chain on oak and I touch it up after each tank of gas. Should throw chips not powder.
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
