55 Series 3ph late model retrofit?
   / 55 Series 3ph late model retrofit? #1
jppugh
JD 855
I have an 89 JD855 and in the technical manual it says the later models or early models with a retrofit have a greater 3-point lift capacity. My question is, what is the retrofit? JD Parts catalog doesn't seem to show a difference. Does anyone here know what the retrofit was? Different lower lift arms to change the geometry?
A guy wants to splurge on the EA 48" aerator but she weighs 850lbs!
Thanks
   / 55 Series 3ph late model retrofit? #2
855 owner could drill holes a little closer in draft arms towards implement attaching balls to increase 3 pt lift capacity a small %. Relocating holes in draft arms would change 3 pt hitch maximum & minimum lift heights. I noticed rockshaft piston part # had a substitute(11A or 11B)
Thanks Jim, I thought it would be something like that.
   / 55 Series 3ph late model retrofit? #4
You're welcome That option is built into my Kubota M7040 3 pt draft arms.
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
(2) JOHN DEERE 8 LUG RIMS (A52708)
(2) JOHN DEERE 8...
2018 Ariens Ikon 52in Zero-Turn Commercial Mower (A56857)
2018 Ariens Ikon...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
