55 Gal Rear Weight
   / 55 Gal Rear Weight #41
I used 2 water filled barrels on top of my 6 ft. Frontier box blade, works perfectly and didn't even need to chain them on as the bottoms wedged good and tight inside the opening. I placed them at an angle, bottoms towards the outside and tops to the center and then filled with water.
1) I guess this is stating the obvious but I assume that you want to keep the 55gal cement filled barrel as close to the ground as possible (without dragging of course) for best results (i.e. preventing rear lift).
2) I intended to put the barrel on the 3pt when doing FEL work. When the FEL is off is it a bad idea to leave the 55gal counter weight on the 3pt? I'm thinking that without the FEL the counterweight might provide too much weight on the rear, i.e. if going up a steep incline might you be more likely to tip backwards with that much weight on the rear and none on the front.
   / 55 Gal Rear Weight #43
I keep mine as low as I can without dragging, as you said. Usually a foot off the ground though, since I run through dips and rough ground at times.
I leave my ballast off most of the time through the spring-summer-fall, and only carry it when doing heavier chores with my FEL. It's on through the winter when I have my FEL snow blade.
   / 55 Gal Rear Weight #44
I accomplished this with my ballast tubs by attaching them ATOP the 3pt drawbar, with threaded studs the protruding down thru the bottom of the tub thru the drawbar for me to add nuts and washers... thus I could leave the 3pt lift 100% relaxed and thus have no load on my hyds, and the load sat real close to the ground.. I could then lift it in full range of the 3pt if i wanted / needed to... To remove it.. just set it on some timbers on the ground... Of course.. I'm not sure why i posted this.. as my ideas were thought of unfavorably before.. so i have no reason to think that will have changed any...
soundguy
   / 55 Gal Rear Weight #45
I have this concern as well. I plan to build a counterweight from a drum oriented horizontally with pins in the center of the ends so it can rotate and not dig in if it touches down. My Mahindra will take a full length drum sideways with only a little end bevelling. Im saving steel scrap to mix in with the concrete for weight. Im aiming for near a ton on the finished product.
Seems like the horizontal arrangement scaled to the tractor would be good for many applications.
larry
   / 55 Gal Rear Weight #46
Anyone know what a 55 gal drum weighs when loaded with concrete? I need to build a ballast for my TC29 and wonder how much weight would be correct for it.
   / 55 Gal Rear Weight #48
Soundguy, got any pics of your counterweight with the additions? Winter's coming and I need a few projects to relieve the boredom. I've gotten a few good ideas already from the previous pics and postings.
   / 55 Gal Rear Weight #49
Last time i posted them they were criticised.. so I don't feel particularly compelled to do so again. the design is too simple, cheap and easy . many of the people here like complicated, expensive and difficult it seems like..
there are already pics of my 20-30 minute / 15$ ballast weight posted here in past messages anyway....
soundguy
   / 55 Gal Rear Weight #50
Soundguy, Please don't feel that way I always look forward to your posts.I'm just so darn mad that a choice few choose to find fault with anything people do and have to comment in a negative way.If they see room for improvements, and or safety concerns, thy should attempt to address it in a nice way. Unfortunately in todays world thats not the norm. I don't think they realize that they undercut just what the purpose of the forums is for..
Ive seem many people and myself included get 'bashed' as I see it.Its difficult to accept that these people are in the minority, and there are many many others who appreciate the postings,and many people who sit by the sidelines and are fearful of posting and getting the same treatment. And with that happening, we all miss out on some good helpful ideas.Sad really, Maybe just post a link for it and then if people have to go criticize it then thats their problem.
Its a tough thing to deal with .. I know first hand.
CAT Chassis Only (A59076)
CAT Chassis Only...
INBOARD DRIVE (A58374)
PALLET FORKS (A58214)
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2019 Ford F250 (A55973)
2019 Ford F250...
2017 Genie GTH-5519 (A53317)
2017 Genie...
