Oil & Fuel 5425 Oil change?
/ 5425 Oil change? #1
Raycando
Went to change the break in oil in my 5425. The drain plug has a square hole, I found that the drive part of a 3/8 socket wrench seemed to fit the hole but it's on so tight I couldn't budge it. Is there a special tool to get that thing off?
/ 5425 Oil change? #2
First time removing the plug there might be some paint in the threads and that can make it a bit stubborn -- might try a short piece of pipe on the socket wrench handle; cheater bar.
AKfish
/ 5425 Oil change? #3
Yep, it's called a long 1/2 inch breaker bar with a 3/8 adaptor on it.
/ 5425 Oil change? #4
Same with my 5603. Scared me at first but it finally broke loose.
/ 5425 Oil change? #5
I use the point of my pocket knife and break the paint seal between the plug and pan. Makes a huge difference in torque needed to remove the plug.
/ 5425 Oil change?
Used a long breaker bar with adaptor, the plug broke lose with a snap noise , must have been sealed up with paint.
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
LOOK! (A65640)
LOOK! (A65640)
2024 CATERPILLAR 265 SKID STEER (A65056)
2024 CATERPILLAR...
