Oil & Fuel 5425 Oil change?
/ 5425 Oil change? #1
Raycando
Went to change the break in oil in my 5425. The drain plug has a square hole, I found that the drive part of a 3/8 socket wrench seemed to fit the hole but it's on so tight I couldn't budge it. Is there a special tool to get that thing off?
/ 5425 Oil change? #2
First time removing the plug there might be some paint in the threads and that can make it a bit stubborn -- might try a short piece of pipe on the socket wrench handle; cheater bar.
AKfish
/ 5425 Oil change? #3
Yep, it's called a long 1/2 inch breaker bar with a 3/8 adaptor on it.
/ 5425 Oil change? #4
Same with my 5603. Scared me at first but it finally broke loose.
/ 5425 Oil change? #5
I use the point of my pocket knife and break the paint seal between the plug and pan. Makes a huge difference in torque needed to remove the plug.
/ 5425 Oil change?
Used a long breaker bar with adaptor, the plug broke lose with a snap noise , must have been sealed up with paint.
HERRING 500 BBL FRAC TANK (A68842)
HERRING 500 BBL...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
TWO PALLETS OF HOSES AND EXTENSION CORDS/LIGHTS (A67714)
TWO PALLETS OF...
2005 Freightliner FLD120 Ambulance (A66736)
2005 Freightliner...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
