5410 Transmission won't shift in Cold weather
   / 5410 Transmission won't shift in Cold weather #11
My 5310 had this problem, drill a 1/8 inch hole thru the bottom plate and let the water out, cured my problem
   / 5410 Transmission won't shift in Cold weather #12
My 5303 would do the same thing. I took the cover off the bottom [4 bolts I think]. I warmed the area first with a propane torch as I didn't have electric where the tractor was kept. A lot of water came out as cover came loose. No problems after that. The place I bought the tractor from replaced the rubber boot just before I bought it so it must of been cracked.
2020 CAT 308 (A53317)
1994 Club Car Electric Cart (A56859)
1994 Club Car...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
