5410 Transmission won't shift in Cold weather
   / 5410 Transmission won't shift in Cold weather #11
My 5310 had this problem, drill a 1/8 inch hole thru the bottom plate and let the water out, cured my problem
   / 5410 Transmission won't shift in Cold weather #12
My 5303 would do the same thing. I took the cover off the bottom [4 bolts I think]. I warmed the area first with a propane torch as I didn't have electric where the tractor was kept. A lot of water came out as cover came loose. No problems after that. The place I bought the tractor from replaced the rubber boot just before I bought it so it must of been cracked.
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
HIGH END MINI GOLF CART (A58216)
HIGH END MINI GOLF...
2811 (A58376)
2811 (A58376)
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
(3) HOT TUB PUMPS & SMALL TORCH SET (A58374)
(3) HOT TUB PUMPS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
