54" ver. 60" removal
/ 54" ver. 60" removal #1
bikemiser
Bronze Member
East Central Illinois
Kubota BX1830
54\" ver. 60\" removal
I have removed my 54" mmm, so I know how that goes but this weekend I will be doing the 50 hrs. hydro change on my sons BX2230 which has a 60"mmm. Is the removal of 60"mmm the same as 54"? Can I drain the hydro oil without removing the mmm? Thanks for comments.
/ 54" ver. 60" removal #3
Re: 54\" ver. 60\" removal
Can you? Yes. Will it be easy? Definately no. Take it off. Your job will go much better.
60" and 54" will R&R the same, just have to manuver the 60" around the tires a little more.
/ 54" ver. 60" removal #4
/ 54" ver. 60" removal #5
I used to put plywood down and pull the 60" MMM out from under my BX2200...because I don't have cement on the floor of my shed, just crushed stone.
Now I just pull the mower out without using the plywood.
Not a big deal...not young anymore either... /forums/images/graemlins/shocked.gif
/ 54" ver. 60" removal #6
/ 54" ver. 60" removal #7
My manual says to drive over MMM. I took it off first by lifting the tractor with Hi Lift Jack - because I did not want to run the tractor.
Drove over it to get it back on, works just fine.
/ 54" ver. 60" removal #8
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Coats 90X-AH-L Tire Changer Machine (A61573)
Coats 90X-AH-L...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2007 Ford F-150 Pickup Truck (A61573)
2007 Ford F-150...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
