Snow 54 quick hitch blade
   / 54 quick hitch blade #11
Bingo!! Glad ovrszd put up some good pics of the "culprit"..
Now, trying to figure if ovrszd has his blade in the living room, or if the comfy chair is in the shop.. :D
Looks like some additions were made to the blade to add some length (width). Nice!
   / 54 quick hitch blade #12
The comfy chair is Willard's (shop dog). :)
I added 3" to each side so I could blade snow with it at full angle without the tractor driving on the unbladed snow.
Hey Ovrszd! Thanks for the pics. Theyæ±*e great! I could use a few more though if youæ±*e willing and have the time...? I could use a measurement of the depth of the bracket. I知 curious how far in it sits...if itç—´ touching the backside of the plow or thereç—´ a small gap.. A height of the base piece where the springs connect (looks to be about an inch or so) would help. Also, whatç—´ the thickness of the steel used? 1/4? 3/16? Thanks again for what you致e sent!
   / 54 quick hitch blade #14
There's a small gap at the center of the blade curve.
Yep, about an inch between the top of the bracket and the moldboard crossmember that the top end of the springs fasten to.
Bracket metal thickness is 3/16". I'm sure it's not mild steel. Were I building one, I'd use 1/4" mild steel simply because of accessibility and ease of working with it.
I keep my moldboard latched all the time. Even added a bolt/nut on the side opposite the factory latch.
Hey ovrszd! I知 starting the fab on my blade support, and I知 using that 菟ivot rod as my starting point. (I知 referring to the solid rod that runs parallel to the blade along the bottom of the bracket, closest to the plow.) i will base the remaining holes Location from that. Any chance you can get a center measurement of that hole for me? I知 trying to use the pics you sent, but the tape is a bit too far away. I知 guessing around 1 up and maybe 1 in, to the center of that hole location? The next hole (towards the tractor, away from plow) appears to be 4.25 from that 菟ivot rod center and maybe 2.375 up from the bottom? And the top hole with the black solid rod, appears to be about 7 or so straight up from that? The last measurement I need would be the distance from the spring holding Cross member piece, towards the back of the bracket, (or front of tractor). I plan to use a piece of angle iron and need the lengths. I知 guessing it痴 about 2 H x 3.5 W? Hopefully that痴 not to confusing to understand... Thanks!
   / 54 quick hitch blade #16
All of your estimates are correct.
The spring bracket is stamped metal, 1.5x2.
Were I building this I would use flat plate for the sides pieces. If using mild steel, I'd use 1/4" thick.
I'd use common angle iron for the bottom spring bracket.
I'd use the blade to correctly align those holes.
I'd use the tractor lift bracket to correctly align the solid rod at the top and to locate the bottom latch holes.
Anxious to see your progress.
We had some 3/16 hot roll lying around, so that痴 what I used for the sides. I currently have them C-clamped to the blade and marked the pivot hole, but was curious about the distances away from the blade. I know it shouldn稚 be touching the blade, so I stacked up some washers, placed them on the high spot of the blade radius and went from there. I知 having trouble posting pics, but I would sure like to share them... I値l keep working and taking pics and hopefully find a way to post them.
   / 54 quick hitch blade #18
If your pics are on your computer, click the "go advanced" button, and then the "manage attachments"
There you can "add files" and browse for where they are. Once located, click "upload" and you should have it.
Or just locate the files wherever they are, and upload them.
Shout out if run into a problem.
Pics will be on my phone. I could send them to my email I suppose, then save them to the computer and upload that way...?
Can稚 seem to find the upload feature when using my phone... And I notice the hieroglyphics that form when I post/reply using my phone too. Or do you, as readers, not see that?
Misc Pallet of Toolbox, Welding Parts, and Torch Carrier (A57454)
Misc Pallet of...
Mac 3200 Chainsaw (A57454)
Mac 3200 Chainsaw...
Bunker Rake (A59228)
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
CAT D8 (A58216)
CAT D8 (A58216)
