5320 brake issue
/ 5320 brake issue #1
KeithyGeorge
G'day all,
I have a problem with my 5320. The brakes go very spongy almost non existent after using the PTO for while say more than 30mins. If the PTO isn't used the brakes are fine.
The brakes when the issue occurs come good after pumping them however then return to being not there.
I had this issue a while back and the tractor has had little use since
https://www.tractorbynet.com/forums...ng/421147-jd5320-541-fel-hydraulic-issue.html
thanks
Mark
/ 5320 brake issue #2
I had an issue just like this in my JD 5520 and it turned out to be a sticky rear remote lever. Why it affected the brakes I don't know. After trying lots of things, I wiggled the remote lever back and forth a little and problem solved. If you have a rear remote, try wiggling the lever.
/ 5320 brake issue
Thanks I will give that a try!
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
John Deere Z994R (A60462)
John Deere Z994R...
