5220 john deere won't start
/ 5220 john deere won't start
I'm pretty sure that's the setup I have. Haven't had a chance to work on it anymore but that diagram will really help. Thanks
Finally got the seat off, darn that thing was heavy, doesn't seem to be anymore damage. The switch on mine has six wires, thought it was seven, but only six. Guess I'll call deere in the morning to see if they have one or get it ordered. Thanks
/ 5220 john deere won't start #22
I just had a JD 5500 which had 12volts at the battery but testing the positive cable coming out of the battery was 2 volts. Had to replace the positive cable. Worked fine since.
Went to john deere this morning and got switch, put it on and everything works fine. You know, mine was a six wire but I looked in the plug and it only uses four. Whatever, I'm just glad it's fixed. Thanks again for all the help.
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
3PT HAY SPEAR (A63291)
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
