5210
   / 5210 #1
nickyterry
Temp. gage on 5210 goes all hot quickly have changed sender not the prob any thoughts?
   / 5210 #3
The following was taken from the tech manual TM1716 using an ohm meter test the readings from the sensor. If you do not have a way to measure the actual temp of the engine you should see the ohms changing.
To test the temp gauge if you have some resistors put them in place of the sensor can do this with just the ignition on. Hopefully the problem is not in the cluster.
You can also make sure the wire from the sensor to the cluster is good. It is bare in a spot and touching metal you will get the results you are getting.
60°C (140°F) 134 ± 13.5 ohms
90°C (194°F) 51.2 ± 4.3 ohms
100°C (212°F) 38.5 ± 3.0 ohms
   / 5210 #4
Unplug the sensor wire. If no change; the wire from the gauge to the sensor could be shorting to ground, or gauge is bad.
   / 5210 #6
Those instrument clusters are notorious for going bad. My 5310 did. It affected my fuel gauge and my temp gauge.
   / 5210 #7
Welcome to TBN.
Wondering if you check radiator fluid also if radiator fins are clean...sometimes it's the easy things.
Kubota B7100 Tractor (RUNS) (A50774)
Kubota B7100...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
10ft Fork Extensions (A50322)
10ft Fork...
