5210
/ 5210 #1
nickyterry
Temp. gage on 5210 goes all hot quickly have changed sender not the prob any thoughts?
/ 5210 #3
The following was taken from the tech manual TM1716 using an ohm meter test the readings from the sensor. If you do not have a way to measure the actual temp of the engine you should see the ohms changing.
To test the temp gauge if you have some resistors put them in place of the sensor can do this with just the ignition on. Hopefully the problem is not in the cluster.
You can also make sure the wire from the sensor to the cluster is good. It is bare in a spot and touching metal you will get the results you are getting.
60°C (140°F) 134 ± 13.5 ohms
90°C (194°F) 51.2 ± 4.3 ohms
100°C (212°F) 38.5 ± 3.0 ohms
/ 5210 #4
Unplug the sensor wire. If no change; the wire from the gauge to the sensor could be shorting to ground, or gauge is bad.
/ 5210 #6
Those instrument clusters are notorious for going bad. My 5310 did. It affected my fuel gauge and my temp gauge.
/ 5210 #7
Welcome to TBN.
Wondering if you check radiator fluid also if radiator fins are clean...sometimes it's the easy things.
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
1996 Aspen FP601 Single Pump T/A Fracking Pump Trailer (A64194)
1996 Aspen FP601...
Wooden Glider Chair (A64557)
Wooden Glider...
2026 Electric Tricycle (A64194)
2026 Electric...
2023 BOBCAT L28 ARTICULATED WHEEL LOADER (A65053)
2023 BOBCAT L28...
