5205 rear lights
/ 5205 rear lights #1
marcin
Bronze Member
Texas
john deere 5205, 1968 john deere 5020
I recently installed the rear lights on my 5205. Everything worked fine and today while driving the tractor to put away, the rear lights started flashing irregularly and then eventually quit. The flashing arrow lights on the dashboard now no longer flash, but stay lit on constantly when I turn the light switch, the rear lights do not work in any position of the light switch. I checked the fuses, connections - everything seems to work fine. I didn't check the bulbs, but what are the chances all would burn out. What could this be? relay? Thank you for any help.
M
/ 5205 rear lights #2
I would check the battery. When the battery on my 6415 was getting weak the lights did strange things. My flashing warning lights and turn signals malfunctioned. I found out there was no flasher, it is built into a control unit. A new battery solved my light problems.
2011 John Deere 6430 (A64911)
2011 John Deere...
2017 Ford F-250 Ext. Cab Service Truck (A66736)
2017 Ford F-250...
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
2007 Ford F-550 (A64911)
2007 Ford F-550...
Auger Bit (A64912)
Auger Bit (A64912)
2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2023 Kubota...
