5200 injection pump
/ 5200 injection pump #1
Harry in Ky
Elite Member
Winchester Ky
Allis Chalmers ED 40
Anyone know the trick involved in separating the drive gear from the pump shaft? I didn't see an access cover on the timing gear front cover so I thought maybe the pump was simply a splined shaft. Parts book shows gear held on with a nut(so much for it being that easy). Also shows a plug of some sort threaded into timing cover where it might line up with said nut. Is there maybe some special tool that threads into this hole and provides a trick to pop the gear loose once the nut is backed off?
/ 5200 injection pump #3
I think one removes plug(parts key #6) to access the nut/washer on inj pump shaft. Be sure and put engine on #1 TDC before removing the nut.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2019 Chevrolet Express Box Van, VIN # 1HA3GTCG9KN007839 (A65563)
2019 Chevrolet...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
