5145 service interval reset
/ 5145 service interval reset #1
TNbrokentrees
Mahindra 5145
Hello, new to posting not new to tractorbynet. I have a Mahindra 5145 that I have just performed the 50 hr service on. Despite hours of research and experimentation, trying various procedures from online, scanning my tractor with a Bluetooth obd dongle and the Torque pro app, unplugging the most likely fuses etc etc, I am unable to reset the service interval alarm. I even purchased a pdf service manual, of course the section for sevice intervals was oddly deleted. One procedure I saw involved key cycles and the trip meter switch which makes sense. My trip meter switch does seem glitchy however, so if the procedure has something to do with that, it may not be working properly. Also there is no "reset" fuse or service fuse in the fuse panel under the hood. Thanks in advance.
/ 5145 service interval reset #2
Page 35-26 covers it, i looked at the service manual the dealer had and it also lacks group 8 "Routine Service Schedule".
The pdf I have is an exact copy of the service manual that the dealer had as far as i could tell.
/ 5145 service interval reset #3
Assuming the 50 hour service includes an oil change, just write the date and hours on the oil filter. Or.....keep a new oil filter on your shelf and write it on the filter box (just May be easier to notice/remind you)
/ 5145 service interval reset #4
I think the point is that the light and beeping is distracting if you do not reset it. I do not have my 5100 series yet but the manual indicates blinking and beeping (I think that is what I read anyway)
/ 5145 service interval reset #5
yes...I understand.
worst case is use the BFH.......that'll stop any blinking and beeping.....
/ 5145 service interval reset #6
ROFLMAO, yes the BFH will stop that, but may stop other things that you want to keep going.
/ 5145 service interval reset #7
Hello. 5145 here just learned how to reset maintenance beep. Turn key on. Don't start. Press the little black button on the dash hardly looks like a button. Hold it until the beeping stops. Roughly 30 secs. Release... Then press again. Single press no need to hold. Then turn key off and back on if you want to check to make sure it worked. Worked for me
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2022 EZ-GO ELITE...
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
Car Hauler Trailer (A64556)
Car Hauler Trailer...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
