5130 Trans. disengages.
/ 5130 Trans. disengages. #1
Akwingnut
Wasilla, Alaska
MX110, 5130
My 5130 is having an issue with the synchromesh trans. at times it will act as if the tractor is put in neutral while in motion. If I stop and move the shuttle lever to reverse the tractor sometimes will start to move then put in forward and all's well for a short time then it does this again, acts like clutch is disengaging. Any info would be great, thanks fellas for your suggestions in advance.
/ 5130 Trans. disengages. #2
Check the shuttle valve to see if you have 7 ohms. There is actually about seven things that it could be for what you have described.
Thanks Art I'll check that. The other thing I've found is this only happens when turniing.
