Backhoe 511 backhoe subframe
/ 511 backhoe subframe
No more worries about mating a Bradco subframe to a non-Bradco hoe. I finally found a 611. Pick it up Friday. Now I need to order the subframe and figure out what to do on the PTO pump and reservoir.
I appreciate all the help and comments.
Bob
/ 511 backhoe subframe #52
Bobvt said:
No more worries about mating a Bradco subframe to a non-Bradco hoe. I finally found a 611. Pick it up Friday. Now I need to order the subframe and figure out what to do on the PTO pump and reservoir. I appreciate all the help and comments.
Bob
That's great news Bob! :) I am jealous! ;) Can't wait to see the pix of that monster! :cool: Just remember to go big on the PTO pump rating so you can meet the 611's hydraulic flow requirements at something less than rated engine RPMs for 540 RPM PTO speed. :cool:
Dougster
/ 511 backhoe subframe #53
Bob
Are you using the bradco pto pump ? I would recommend skipping them and just buying a prince. If you've read any of my backhoe posts in the past you'll note that the bradco pumps can be a royal pain. As far as I know the tank is fine. A tank is a tank. That is the only trouble I have ever had with my setup is the pto pump.
/ 511 backhoe subframe #54
bindian said:
dfkrug,
Yeah, I do the same thing while downloading photos, I go do something else. :( I use Netscape for my browser, as I do not like Internet Explorer. I can not right click to resize a photo. :(
All Windows XP users can easily (and temporarily) resize photos for
emailing purposes. I do not know if Vista supports that, and Macintosh
users, who knows? Just view your JPG files in the Windows Explorer,
right-click the one you want and choose SENDTO and follow the
directions. No need to use photo-editing s/w or browser. Easy.
/ 511 backhoe subframe #55
Just saw a huge Prince PTO pump mounted on a Massey yesterday. What a beast! :eek:
I don't know from personal experience if Prince pumps are good or bad... but I do know that you can get them in cast iron and in quite a size range. That latter feature is a very good thing if you aren't into running your tractor's engine at full rated RPMs just to get the backhoe to work. :eek:
Dougster
Tim,
I have been looking at the Prince pumps. Trying to decide with one to get (11.4 gals., 17.1 gals or 21.0 gals). I'm leaning toward the 17.1 gal pump. Given the Bradco gets "optimum performance with 9-12 gpm hydraulic systems", the 17.1 gal. pump should work fine with the tractor running at 1,400- 1,500 rpms. (At 1,500 rpms, the pump should put out a little over 12 gpm.) I think, I want to stay away from the 21 gal. pump, as the increased flow will generate more heat.
I'm going to talk to the Mahindra dealer about pump requirement and get a price on the hydraulic reservoir. I've found several reservoirs on the net with varing sizes and mounting flanges. I'll have to see if Mahindra price is comparable. If not, I'll wait until I get the subframe installed and see what I have for space and how one can be mounted.
Bob
/ 511 backhoe subframe #57
Bobvt said:
Tim, I have been looking at the Prince pumps. Trying to decide with one to get (11.4 gals., 17.1 gals or 21.0 gals). I'm leaning toward the 17.1 gal pump. Given the Bradco gets "optimum performance with 9-12 gpm hydraulic systems", the 17.1 gal. pump should work fine with the tractor running at 1,400- 1,500 rpms. (At 1,500 rpms, the pump should put out a little over 12 gpm.) I think, I want to stay away from the 21 gal. pump, as the increased flow will generate more heat.
Hi Bob - Remember that you're not dealing with a 511... but a 611. The "optimum performance" range for the Bradco 600-series machines is not 9 to 12 GPM as it is for the 500-series... but 11 to 14 GPM. I'd assume that the bypass setting is also increased 2 GPM (+/-) from 14 GPM to maybe 16 GPM. Check it out:
http://www.bradcoattachments.com/_includes/fileblob.asp?I=304&table=product&ext=pdf&name=609 & 611 BH Broch 0610-3.pdf
Dougster
Dougster,
Thanks for bring that to my attention. The 611 brochure I have says 9-12 gpm. It is probably 3 - 4 years old. I guess I'll have to reconsider the 21 gpm pump. I'll be interested to see what my Mahindra dealer says on pumps. He has handled the Bradco line longer than the Mahindra line and seemed be be acquainted with the 611.
Bob
/ 511 backhoe subframe #59
Bobvt said:
Tim,
Bob
Bob I originally ordered my 511 without a pump. After telling the dealer I wanted a pump they had to scramble to get the right parts. Not sure how easy it is to convert to a pump setup after the fact so you might check on that as well. Also, when the pump is installed on the pto, there is very little clearance between the pump and the back of the pump resivior so if you buy something other than bradco's pump you'll just want to make sure it will fit in that space. I can measure mine if you like, for example, measurement from drawbart mount etc.
Bradco ships with a crappy pto extension. I bought a coated aftermaket one that doesn't rust so it is easier to take on and off. has a yellowish shiny look to the metal.
I like the idea of a prince pump for the simple fact that they are readily available. It is really hard to find information on the pump that bradco uses. I run my system a little under pto speed and it works great. Kinda depends on what you are doing at the time. Too fast and you are riding a bull. :)
/ 511 backhoe subframe #60
Bobvt said:
Dougster, Thanks for bring that to my attention. The 611 brochure I have says 9-12 gpm. It is probably 3 - 4 years old. I guess I'll have to reconsider the 21 gpm pump. I'll be interested to see what my Mahindra dealer says on pumps. He has handled the Bradco line longer than the Mahindra line and seemed be be acquainted with the 611.
Bob
Hi Bob - I'm guessing that when all the calcs are done and checked, you will end up buying the larger pump. :)
Yes, there are old and current websites out there with incorrect numbers for the 609/611. The PDF file I linked is the current spec direct from Bradco. :)
Dougster
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
golf cart (A56859)
golf cart (A56859)
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2018 PJ Trailers 14ft T/A End Dump Trailer (A59230)
2018 PJ Trailers...
