Tires 5103 Tires
/ 5103 Tires #1
CWP37
Hill Country, TX
John Deere 5103 w/ 512 LDR
What size type of rear tires are you guys running on your 5103s? I have 13.6-28 Ag tires and it seems like I get stuck a lot. They are like trenchers in the mud.
Would wider tires be an answer?
/ 5103 Tires #2
Wider tires and no ballast might help. My 5105 (roughly same size) has 16.9x28 R1 rears. The base tire on a 5105 is 14.9x28 but the dealer didn't order those and said I wouldn't want them. A 13.6 sounds awfully skinny to me.
/ 5103 Tires #3
I am running the "standard issue" tires that came with the 5103/w/loader with liquid ballast done by the dealer, I think they are the 13.6 Ag tires as you described. Sorry I can't recall for sure.
I purposefully have avoided (or simply just couldn't do any) mowing, etc. of late due to the tremendous rains (over 17" in 1.5 months in Madison County, Texas). Too "squishy" and I don't want my new tractor out in the elements until it dries out enough to get traction. I guess I am too conservative here. Also, I don't have anything to pull me out.
Finally got some mowing in about a week ago but it rained again (1.75 inches) , so I am letting it dry out a tad bit more. I am NOT complaining, mind you, we have burned up in so many prior years...
So instead of using the tractor, I just "let" my battery short out, etc. (see thread herein). :confused: Go figure. Patience is NOT always a virtue. :)
Good luck, Chip! I understand your frustration but I simply refuse to use the tractor until conditions get better. I believe our 5103 choice of a tractor is one *heck* of a good buy for the money, but I understand why you might want a 4 wd, that is why I *almost* got the 4wd 990. But, I think this was a wiser choice for the long haul. And, I didn't want to tear up the land with huge gouges due to getting stuck or nearly stuck, but that attitude of mine will change over time I am sure. I look forward to seeing ideas about the wider type of tires.
Taylor
/ 5103 Tires
I agree with about having patience. Unfortunately, a virtue I have little of.
Getting stuck is operator stupidity in most cases. It just seems like I lose traction real fast, even when it's dry.
I'm thinking of putting some 16.9 wide tires and see how they work. Anybody have any idea what that should cost?
/ 5103 Tires #5
First thought --- 13.6x28 R1 is the same OEM tire for the much smaller JD1070. Seems to me that on a 5103 that you'd be way under-tired!
Another consideration is whether the larger 16.9's will fit on your 13.6 rims.
If you have to buy rims with the new rubber --- well, that would make a nice down payment on a new 5103 4WD.
AKfish
/ 5103 Tires
Just another reason to trade up. Just what I need.
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
Parker Spreader (A64119)
Parker Spreader...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65579)
IMPORTANT PLEASE...
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
