5103 and 512 hydraulics question
   / 5103 and 512 hydraulics question #1
CWP37
Hill Country, TX
John Deere 5103 w/ 512 LDR
The two loader "shoes" that attach the buckets/bale spear, etc. are tilting at a different rate. It's difficult for me to synch them to pick up my bucket. They work fine once I have the bucket pinned on. Anybody know how to adjust the pressure or speed?
   / 5103 and 512 hydraulics question #2
This may help:
On my 410 loader there is a rod that runs beetween the two "shoes", it is pinned into each shoe with a small 1/4" pin and cotter. When I had the same problem I found one of the pins was sheared.
Look at parts 4, 5 and 8 in the attached picture:D
Thanks for the reply and the time you took to send me the diagram. I actually popped out the whole cross bar last weekend and have since replaced the pins. The problem showed up before I did that. The problem is that my right part #10 moves faster than my left part #10. I'll check all of the pins the next couple of days to see if I broke one and report back.
   / 5103 and 512 hydraulics question #4
Well, if the pins are OK then I think you will just have to live with it. I know mine will get about 4" or so out of wack, but I just push them against the bucket or forks as I try to hook the top in place.
New 52" Skidloader 4in1 Bucket (A50775)
New 52" Skidloader...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
Gravely 260Z 60in Zero Turn Mower (A55787)
Gravely 260Z 60in...
2021 Bobcat S740 (A53314)
2021 Bobcat S740...
golf cart (A55758)
golf cart (A55758)
