5103 3 Pt Hitch Stuck in Raised Position
   / 5103 3 Pt Hitch Stuck in Raised Position #1
TrioDeere
My 2005 5103 3 pt hitch will raise but not lower. Levers are all in the correct position. Any ideas?
   / 5103 3 Pt Hitch Stuck in Raised Position #2
Welcome to TBN:D
Have you checked the rate of drop knob for the 3PH to make sure it is open?
Yes, it's hidden underneath the seat and it was open
   / 5103 3 Pt Hitch Stuck in Raised Position #4
I have a 5203 that the 3 pt doesn't lower until I put some weight on it. I have messed with the return under the seat so I may have messed with the ability to lower with out weight. I need to check that out. If this is not the case, I need to know that also.:)
Took it to John Deere and they removed the seat then removed the arms rate of drop valve. The valve was cleaned, sanded lightly, and greased.
Greenworks 2700psi Portable Pressure Washer (A55787)
Greenworks 2700psi...
1994 International 3800 Bus (A55852)
1994 International...
30ft Highway Trailer Co. Lowboy (A55301)
30ft Highway...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 60"...
UNUSED JCT HYD TRENCHER (A54757)
UNUSED JCT HYD...
New Holland 316 Square Baler (A50775)
New Holland 316...
