5103 3 Pt Hitch Stuck in Raised Position
   / 5103 3 Pt Hitch Stuck in Raised Position #1
TrioDeere
My 2005 5103 3 pt hitch will raise but not lower. Levers are all in the correct position. Any ideas?
   / 5103 3 Pt Hitch Stuck in Raised Position #2
Welcome to TBN:D
Have you checked the rate of drop knob for the 3PH to make sure it is open?
Yes, it's hidden underneath the seat and it was open
   / 5103 3 Pt Hitch Stuck in Raised Position #4
I have a 5203 that the 3 pt doesn't lower until I put some weight on it. I have messed with the return under the seat so I may have messed with the ability to lower with out weight. I need to check that out. If this is not the case, I need to know that also.:)
Took it to John Deere and they removed the seat then removed the arms rate of drop valve. The valve was cleaned, sanded lightly, and greased.
Kubota M4700 51HP Utility Loader Tractor (A55787)
Kubota M4700 51HP...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
PALLET OF MILITARY STRAPS (A54756)
PALLET OF MILITARY...
MISC CABINET PARTS (A54756)
MISC CABINET PARTS...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
