5100E 540e PTO will not engage
   / 5100E 540e PTO will not engage #1
whatsplanb
euless, texas
ford
I have a “new to me” 5100E, the 540e PTO will not engage. Not sure if there is a problem, or I’m just missing something. Any ideas?
   / 5100E 540e PTO will not engage #2
Will the normal 540 pto engage? To engage 540e, you must shift the 540 lever and then pull up on the yellow pto switch knob. Also engine speed needs to be under 1700 rpm.
Ok,thanks. That’s helpful info, I don’t think I’ve tried it that way. Tractor is at a remote location and it will be 3 weeks before I can try that. I’ll let you know if you’ve solved my problem. Thanks!
   / 5100E 540e PTO will not engage #4
I was guessing the lever would not move and a linkage problem. Older models had linkage to limit rpm too, I am guessing rpm is now electronically controlled, so maybe like jd110 says if you try and engage above 1700rpm it will not allow engagement.
Ok, that’s going to help with my thought process, when I start trouble shooting. It’s going to be a couple more weeks till I get back to it. I will update. Thanks!
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2020 John Deere 7230R (A53317)
2020 John Deere...
CONIBEAR EQ CO HYD SEED SPREADER (A57192)
CONIBEAR EQ CO HYD...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2022 BOBCAT S740 SKID STEER (A52707)
2022 BOBCAT S740...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
