5100E 540e PTO will not engage
   / 5100E 540e PTO will not engage #1
whatsplanb
euless, texas
ford
I have a “new to me” 5100E, the 540e PTO will not engage. Not sure if there is a problem, or I’m just missing something. Any ideas?
   / 5100E 540e PTO will not engage #2
Will the normal 540 pto engage? To engage 540e, you must shift the 540 lever and then pull up on the yellow pto switch knob. Also engine speed needs to be under 1700 rpm.
Ok,thanks. That’s helpful info, I don’t think I’ve tried it that way. Tractor is at a remote location and it will be 3 weeks before I can try that. I’ll let you know if you’ve solved my problem. Thanks!
   / 5100E 540e PTO will not engage #4
I was guessing the lever would not move and a linkage problem. Older models had linkage to limit rpm too, I am guessing rpm is now electronically controlled, so maybe like jd110 says if you try and engage above 1700rpm it will not allow engagement.
Ok, that’s going to help with my thought process, when I start trouble shooting. It’s going to be a couple more weeks till I get back to it. I will update. Thanks!
(APPROX.128) UNUSED 1X6 TONGUE & GROOVE (A57192)
(APPROX.128)...
202474 (A54757)
202474 (A54757)
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE FT13C EXCAVATOR (A57192)
UNUSED FUTURE...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2015 Kia Sportage SUV (A55853)
2015 Kia Sportage...
