5093E radio installation
   / 5093E radio installation #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
Bought a 2012 5093E with no radio installed..Housing is up top in right rear of cab...Are speakers and wiring already in place? How can I install one myself and which model will fit?
   / 5093E radio installation #2
Yes. If you pull off the front cover to the radio housing you should find the antenna wire, radio harness, and possibly a another black wire (the ground). On my 5055E I had to cut the black wire and splice it to the radio for the ground, as the harness had no ground. My 5085E didn't have a ground wire at all in the housing so I had to use one of the cab bolts as the ground...
Anyway get you a 88-99 Volkswagon harness, it's only a couple of bucks, and it fits the JD harness.
Most any standard stereo will fit.. I use Pioneer's with no problem.
Outstanding! Thanks...Speakers are already in?????????
   / 5093E radio installation #4
Should be.
How did you wire your antennae?
   / 5093E radio installation #6
Is there an antennae cable in the compartment? There should be one there.
Outside above the right hand door there should be a little mount jutting out of the top of the cab. An antenna screws in there.
I'll check ...Thanks
   / 5093E radio installation #8
Exactly. Use the VW adaptor harness that you can buy at Best Buy or order online. It is basically as easy as matching the wires from the stereo to the harness crimp them and plug and play. How I did mine was to drop the radio box down off the cab and mounted the stereo in it and then plugged everything up and used one of the 4 mounting bolts for my ground, because the ground they give you sometimes does not work. The speakers are already up in there, but I switched mine out to Polk Audios. The are much brighter and sound much cleaner than the paper ones they put in there. I put an Alpine head unit in it with a USB port and a 1/8th inch stereo in plug. It cost less than 100 bucks at Best Buy. It is was rated at 25watts/channel, but it probably only has 10 which is enough in that tractor. It sounds great. I was using my iPod in there, but it was always bouncing around, so I just a 2 gig jump drive and loaded it full of music and I leave it in there all the time and never misses a beat.
Good luck. Let us know how it goes.
Great! thanks..
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A53426)
2015 INTERNATIONAL...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2015 TOP HAT TRAILER 18 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
