3-Point Hitch 5085M 3pt hitch very choppy when raising
   / 5085M 3pt hitch very choppy when raising #11
hi, check out this thread hydraulic manifold case looks like it has been a problem with the hydraulic pump manifoild case.
   / 5085M 3pt hitch very choppy when raising #12
Yup.. Remember it well. Everything's been all good with my 75M since that warranty fix. No problems whatsoever.
I'd buy another M in a heartbeat! Deere did good by me and Bigfoot.
AKfish
Sorry guys, been away for a while. So as it turns out, the issue went away completely once I put the bush-hog on the back, which is much heavier (2,600 lbs vs. 800 lbs). I have since switched back to the log grapple and the issue has not returned. Perhaps if I leave the light grapple on there for a while, the symptoms will develop again?
I'm still going to check the screen, etc, but it least it seems there was nothing wrong that required immediate attention.
I too remember reading that hydraulic manifold case. I'm glad that doesn't appear to be the issue as I'm long out of warranty!
   / 5085M 3pt hitch very choppy when raising #14
That's good news, indeed! I haven't looked at my OM in awhile or the Tech manual but, I don't think the M series has a sump screen. Just that big, screw on filter on the pump manifold.
I bought a chain-ratchet filter wrench to change that filter.
I think the manual calls for a filter change @ 600 hrs.
There actually is a filter AK. Here's what mine looked like at 100 hrs:
And the mysterious o-ring fragments I found inside:
I did a full service, including new filter at 100 hrs. My old vs. new fluid:
I'm at a little under 700 hrs, so maybe it is almost time to do it again.
   / 5085M 3pt hitch very choppy when raising #16
Hmmm... Appreciate that info. I'm just over 600hrs on the 75M and plan on a change-out this Spring. Have to do some homework, beforehand.
SPRING TOOTH HARROW (A52708)
SPRING TOOTH...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
LOT OF REDBAND FENCE WIRE (A58374)
LOT OF REDBAND...
(INOP) FARMALL TRACTOR (A52708)
(INOP) FARMALL...
30" X 20" X 72" METAL SHELF (A52708)
30" X 20" X 72"...
