3-Point Hitch 5085M 3pt hitch very choppy when raising
   / 5085M 3pt hitch very choppy when raising #11
hi, check out this thread hydraulic manifold case looks like it has been a problem with the hydraulic pump manifoild case.
   / 5085M 3pt hitch very choppy when raising #12
Yup.. Remember it well. Everything's been all good with my 75M since that warranty fix. No problems whatsoever.
I'd buy another M in a heartbeat! Deere did good by me and Bigfoot.
AKfish
Sorry guys, been away for a while. So as it turns out, the issue went away completely once I put the bush-hog on the back, which is much heavier (2,600 lbs vs. 800 lbs). I have since switched back to the log grapple and the issue has not returned. Perhaps if I leave the light grapple on there for a while, the symptoms will develop again?
I'm still going to check the screen, etc, but it least it seems there was nothing wrong that required immediate attention.
I too remember reading that hydraulic manifold case. I'm glad that doesn't appear to be the issue as I'm long out of warranty!
   / 5085M 3pt hitch very choppy when raising #14
That's good news, indeed! I haven't looked at my OM in awhile or the Tech manual but, I don't think the M series has a sump screen. Just that big, screw on filter on the pump manifold.
I bought a chain-ratchet filter wrench to change that filter.
I think the manual calls for a filter change @ 600 hrs.
There actually is a filter AK. Here's what mine looked like at 100 hrs:
And the mysterious o-ring fragments I found inside:
I did a full service, including new filter at 100 hrs. My old vs. new fluid:
I'm at a little under 700 hrs, so maybe it is almost time to do it again.
   / 5085M 3pt hitch very choppy when raising #16
Hmmm... Appreciate that info. I'm just over 600hrs on the 75M and plan on a change-out this Spring. Have to do some homework, beforehand.
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
Kubota R5205 (A57148)
LandHonor PTO Skid Steer Attachment (A56857)
LandHonor PTO Skid...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Yellow Posts (A55973)
