5045D Toplink length
/ 5045D Toplink length #11
I also run the cutter with rear wheel on the ground, but have chains instead of the flat bars that are loose when that tail wheel is on the ground. Flows with the ground that way, and the leading edge is adjusted with the 3ph. When 3ph is raised, then the rear wheel is lifted off the ground for transport.
Still waiting for a pic from the OP of how his rotary cutter is setup. Only have the closeup in the OP.
/ 5045D Toplink length #12
Does this mean that when cutting you have the tail wheel running continuously on the ground with weight on it? I don't think it's supposed to work that way. The top link should be able to raise the rear of the mower to the proper height, and the tail wheel should only lightly touch on uneven terrain
Not a good way to run the cutter.. The cutter should float with the ground and cannot the way yours is apparently set up. Waiting for a pic to make any further suggestions.
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2012 Honda Civic Sedan (A59231)
2012 Honda Civic...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2013 Mercedes Benz E350 AWD Sedan (A59231)
2013 Mercedes Benz...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
1977 Heil 6,300 Gallon T/A Tanker Trailer (A59230)
1977 Heil 6,300...
