5035 Remote Hydraulics
/ 5035 Remote Hydraulics #1
timster
Elkins, WV
mahindra 5035
Hi everyone,
New Member Here and I have a pretty basic question about a 5035. How are the rear hydraulic remotes operated?
/ 5035 Remote Hydraulics #2
Should be the far right lever that is higher than the other 2 and it comes up through the fender I believe. Maybe read your owners manual???
Reading the owners manual is a great idea. Since i haven't bought a 5035, I don't own a manual! That makes it kinda hard to do. So I had a crazy idea to ask on line.:eek:
/ 5035 Remote Hydraulics #4
Welcome, timster! Lets see if I can be a little more friendly. I have a 2013, 5035 and the remote leaver is the short leaver down by the seat on the right side. It is a little hard to get to, but I am going to make an extention for mine when I get a chance.
/ 5035 Remote Hydraulics #5
What Make/Model of Tractor Do You Own?:
Did you not answer this question.
The answer is, you pull or push the remote valve lever.
You could order an owners manual so you will know how to operate the tractor before you even get it.
/ 5035 Remote Hydraulics #6
So your rear remote lever is not here? :confused:
I am in the market to buy a new tractor and I really like the 5035. I've been to the dealer and neglected to ask about the rear remotes. Looking at the brochures I see nothing about the rear remotes and I don't see any extra levers cept the one on the fender on some pictures. None of them are close enough to identify its intended purpose.
/ 5035 Remote Hydraulics #8
I think originally, the first rear remote lever was cable operated on the fender [ replaces that cup holder ]. But my 2011 has the 1st remote lever down beside the seat, just inboard of the 3pt levers. If you get the factory add on valves [ 2nd and 3rd rear remote ], they then are remote operated via cable, and the levers are located there in the cup holder area. With the actually valves/couplers in the right rear area. But, that's just my guess. You should be talking to your dealer that can call Chatanooga assembly and get the real story.
/ 5035 Remote Hydraulics #9
Technically...you can mount the control valve(s) anywhere there is room that allows access from the station and routing of the lines/hoses...A dealer will install the qd's and the valve(s) where their engineering directs them to fit their "kits"...
After market and or 3rd party parts are often less expensive and if you're capable of doing your own installation you can save enough $$ for an attachment or two...etc...
/ 5035 Remote Hydraulics #10
As I stated earlier, mine are factory mounted and are down by the righthand side of the seat on 2013 model. Short leaver down low. I have a Backhoe and the lines are connected to the factory rear remotes and on the installation a hook was added to keep the valve made to supply flow to the hoe.
/ 5035 Remote Hydraulics #11
Just noticed my last reply did not post. Like I said, before my factory remote leaver is a short leaver on the right side of the seat down low. When I get a chance I plan on extending it to make it more user friendly. My 5035 is a 2013 model.
/ 5035 Remote Hydraulics #12
Well, maybe it did post. Was not showing up on my end for a while, then it reappeared?
/ 5035 Remote Hydraulics #13
When I bought my new Mahindra 5525 in 2008 I had the dealer install triple rear remotes. The flat top fenders made this an easy job. His design. Cost: $750
Good luck
New/Unused Wolverine 72in Quick Attach Grapple Bucket (A61166)
New/Unused...
TANK MANIFOLD (A58214)
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
1973 GMC C65 Log Truck (A61165)
1973 GMC C65 Log...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
LOT LOCATIONS (A59908)
