5020 throttle linkage adjustment
   / 5020 throttle linkage adjustment
Update.
I was finally able to repair the throttle mechanism, the problem was found in linkage play. First, the speed tube grooves pushed by the hand throttle were stretched. Second, the bellcrank and the swivel it rotated on were worn, allowing for more than rotary motion. Third, one of the holes in shaft #36 was stretched. I replaced the 3 mentioned parts as well as the foot pedal and its lever and adjusted the mechanism according to the procedure in the manual and it all seems to be working great. Thank you all for help.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2016 Morbark Chipper (A55787)
2016 Morbark...
202480 (A54757)
202480 (A54757)
