50 hr service question for b3030hsdc Change the Hydro Fluid?
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #1
soxfan
Bronze Member
Utah
B3030hsdc
Went and got everything today for the 50 hr service and when I told the guy to give me SUDT at the service desk, he said that i did not have a need to change the hydro fluid until 150 hours as that is what they do at the shop and they are one of the largest Kubota dealers in the US. I have read here on the forum to change it at the 50 hr service mark. So should I change it or not? He said If I used it hard every day then maybe i could but since I have had it over a year and only have 50 hrs on it, I should not worry about it.
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #2
If memory serves me the B3030Cab, only takes 4.1 gallons total with both filters changed. If you change only the filters you will lose about 1+/-gallons. So the bottom line is.
Save 3 gallons of SUDT...$49.80+tx
Paid $20K for tractor.
Manual states to change at 50hrs.
After you pull your filters and see all those little pieces of metal attached, you will probably agree with me.
CHANGE THE FLUIDS!
Thanks for the input, I agree, what is another 100 dollars for filters and fluids on a $20,000 machine? Better safe than sorry. Not to mention the warm fuzzy feeling from changing it rather than that nagging doubt I would feel everytime I use it.... Change the fluids it is.....
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #4
I am getting close to my 50 hours. Quick hydro question, is there a metal screen anywhere like I had on my BX?
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #5
I would definitely suggest changing the fluid! I changed mine on my GR2100 at 50 and 175 hours. I was very surprised at the amount of metal and junk in the strainer & fluid at the 50 hour change. Called Kubota and they were not concerned. Same amount of crap at 175 hours.
Then the HST failed at 203 hours .... imagine that. Luckly it failed with about a week of going out of warranty... Yes there is a tractor God.
Although in my case changing the fluid & filter would not have made a difference in the long run (as my unit was doomed from the start... changeing the fluid probably only extended the life some amount of TBD hours) in a healthy machine it cannot hurt to buy what I consider cheap insurance (filters/fluid).
Tony
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #6
AMR-Funny,I was just going to post the same question myself. I'm also nearing the 50 hour service on my B3030HSDC. I had two of those strainers on my B1750. The owners manual doesn't say anything about a screen,but I was reading the Messicks how-to-service page on the B7800 and they showed a screen. Since the 7800 and 3030 are similar machines,it got me wondering. Thanks
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #7
Change your fluid and filters! Get all the little metal peices from manufacturing out of there. With good maintenance the 3030 should give you many years of service.
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #8
If you read the maintainence chart...Kubota Tractor USA - Quick Reference Schedule
You will notice it specifically states that at 50 hrs you CHANGE tranny fluid and you "clean" ( ??) the tranny filter. How one "cleans" a spin on filter escapes me?? but I changed BOTH of the hyd filters on my own at the 50 hr mark
   / 50 hr service question for b3030hsdc Change the Hydro Fluid? #9
My B7800 has the small screen that filters the filings. I had my hydro oil changed when I had my 50 hour service done and there were only a few tiny metal fragments on the screen.
I'd think a 3030 hs that same tubular screen in the hydro plug.
2012 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2012 MAXEY TRAILER...
2019 PJ 25 T/A GOOSENECK TRAILER (A50854)
2019 PJ 25 T/A...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
