50 Hr maintenance
/ 50 Hr maintenance #41
What options besides the three recommended fluids in the owners manual ( exxonmobil, shell donax, bp tractran uth) are there?
I think about any of the other brands recommended for other brands of tractors would probably be fine, ie. Kubota SUDT for example. Some of the guys have used the Tractor supply Traveler premium fluid and report no problems. I decided to just use the Exon Mobile Mobilefluid 424. The Shell donax is now called Spirex. It us up to you to choose, but I have heard some members report issues with using some of the cheaper fluids especially with tractor equipped with Hydrostatic transmissions. Some users report more sluggish operation and more whine noise from the transmissions. I think premium fluids give premium performance, but that is just me.:)
/ 50 Hr maintenance
would the shell spirex be considered economy?
/ 50 Hr maintenance #44
RE: Shell Spirex (formally Donax)
I don't think so.. I believe it to be a premium fluid.
I looked on line and it's expensive. $70-90/5 gal. I wonder if Rotella would suffice. I won't have to worry for awhile. But what to use for top-up?
/ 50 Hr maintenance #45
/ 50 Hr maintenance #46
The Spirax isn't the economy. Here's a list of other oils and capacities that had been posted by another member.
  • Lubricants-Chart-2012-07-20.pdf
/ 50 Hr maintenance #47
I think this statement is the key:
Multi-grade
transmission fluid
rated for
differentials, final
drives, wet brakes,
and hydraulic
systems enclosed in
a common reservoir
It seems like I paid about $216 for 15 gallons for the MobilFluid 424 when I bought 15 gallons of it. But I cannot remember for sure.
Here is an online link, I bought mine locally.
MOBILFLUID 424 (PAIL)
/ 50 Hr maintenance
Great chart, thanks
/ 50 Hr maintenance #49
@ Haltom Equioment Filters for my Machine: Engine oil = $10.66; Hydro = $64.68; Fuel = $5.04. Same prices at MIE.
BTW, a Kioti hat at their store is $6.50 - $7.50. Shipping is $8.00.:confused3:
/ 50 Hr maintenance #50
"Multi-grade
transmission fluid
rated for
drives, wet brakes,
and hydraulic
systems enclosed in
a common reservoir"
I agree, and this is almost word for word, on the Traveller Premium UTF 5 gallon pail ($40.00). Buy 2, and most of us have enough for the transmission, plus enough left over to do the front axle a couple of times....Hill Billy Bob
/ 50 Hr maintenance
I just got off the phone with Kioti's customer service. I got some women on the phone that didn't seem too savy!
She said it's o.k to use synthetic motor oil, and it's O.K to use Shell Rotella Hydraulic Fluid.
/ 50 Hr maintenance
Please be careful, I'm replying to my own post. I don't want to spread any misinformation. I did say that the women from Kioti customer service didn't seem too savy!
I asked her to send me some info on the rotella hydraulic fluid being acceptable to Kioti . She did, apparently she's confusing motor oil with hydraulic fluid. Rotella hydraulic fluid isn't on Kioti's recommended list.
/ 50 Hr maintenance #54
Rotella has a Heavy duty tractor fluid.
Good for transmission, hydraulics and wet brakes.
It works just fine in Kioti tractors. I have in mine.
/ 50 Hr maintenance
I'm sure that your right about the Rotella heavy duty tractor fluid, but if you were to get a hydraulic related failure, and wanted kioti to warranty it, can't you just hear someone saying "tough luck, you didn't use a fluid on our recommended list".
/ 50 Hr maintenance #56
Nope, can't do that.
/ 50 Hr maintenance #57
That is precisely why I used the MobilFluid 424. After the warranty is out, I may look for something cheaper.. depends on how flush with money I am.:D
/ 50 Hr maintenance #58
What Murphy said. AND, if you are using fluids that meet the specs of the manufacturer, regardless if they name every product on your planet, you're covered. That's the facts, Jack. And asking advice from the Kioti Corporate office receptionist is a waste of time. The data sheet states to contact your local dealer with any questions. Buying OEM filters doesn't guarantee anything either, nor does keeping the receipt. You could buy Kioti every filter necessary and then use the cheapest Wally World filters and recycled garbage fluids, then when your engine blows screw on the OEM filter, etc. If Kioti is going to deny a warranty claim, or any other equipment manufacturer, it's more likely going to be related to abuse/misuse like the wrong sized back hoe for an undersized tractor, not which oil you chose for the engine. In the case of the HST transmission if you used a fluid that did not specify wet brake use then it's your problem and they could deny coverage.
In fact, if one READS the fine print ONLY Kioti branded implements are covered if tractor breakage occurs. If you use a xyz brand hoe and break the rear end on the tractor Kioti will NOT cover the repair to the tractor. Recourse would be with the implement manufacturer.
Speaking of expensive, I just laid out $31.95 for ONE GALLON of Yamaha 225HP 4 stroke outboard motor oil! Yikes! But during warranty that's how I choose to fly, 'cause nothing is more expensive to maintain than a 4 stroke outboard motor, so I don't want any headaches, period. Expensive peace of mind.
/ 50 Hr maintenance
What you say makes lots of sense, but never-the-less, I'd like to see the hydraulic fluid Ok'd in writing by kioti.
I'm having a hard time finding any of their recommended hydraulic fluids anywhere. Rotella, and traveller is available locally though.
/ 50 Hr maintenance #60
:laughing:
So you end your long post that I was actually following, with a sentence that contradicts your whole point.
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2022 EZ-GO ELITE...
