Backhoe 50 hour service on MF 1710 TLB
   / 50 hour service on MF 1710 TLB #1
67gtoowner2
Massey Ferguson GC 1710 TLB
Do I need to remove the backhoe attachment before replacing the hydraulic fluid in the tractor or should I leave it attached?
   / 50 hour service on MF 1710 TLB #2
yes remove it.
   / 50 hour service on MF 1710 TLB #3
It won't matter..... unless it is in the way of working on it. No fluid will come out of the BH.
   / 50 hour service on MF 1710 TLB #4
You can't accurately see sight glass when it's mounted. Getting at fill tube a pain with it on also.
Thanks for the input, I plan to remove it for access to the fill tube and sight glass. It is an easy task to remove the backhoe.
Another question:
Do I check the sight glass with tractor idling or not running?
   / 50 hour service on MF 1710 TLB #7
Idling, on a level surface. If the sight glass is totally full, you probably won't be able to tell if it's empty or full; you might look at it first with the engine NOT running (it will be a bit lower) to see if you can see the fluid line in the sight glass. Then start and look again. Better yet, stand back there looking while someone else starts the engine.
Thanks fopr the response
   / 50 hour service on MF 1710 TLB #9
The reason the transmission has a big sight glass, and not a dip stick is the oil level isn't real critical. If it's anywhere in, or close to the sight glass, it's going to work fine.
It can be hard to tell where you're at, especially if you fill it above the sight glass. So, take your time with the last gallon.
2239 (A51244)
2239 (A51244)
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2014 Mack CXU613 Semi (A50514)
2014 Mack CXU613...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
