Backhoe 50 hour service on MF 1710 TLB
   / 50 hour service on MF 1710 TLB #11
The transmission takes 11 litres (quarts). 10 1/2 may not show in the sight glass, 11 1/2 may completely fill it. Keep track of how much you pour in. Check the breather valve on the oil fill cap while you have it out.
   / 50 hour service on MF 1710 TLB #12
Idling, on a level surface. If the sight glass is totally full, you probably won't be able to tell if it's empty or full; you might look at it first with the engine NOT running (it will be a bit lower) to see if you can see the fluid line in the sight glass. Then start and look again. Better yet, stand back there looking while someone else starts the engine.
my GC2400 manual,page 56, which (iirc) is the same procedure for ALL 17xx series is engine off.
I can check newer 1723 and 1725M series if needed today but when servicing a 1725M few weeks ago procedure was same.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
jet ski trailer (A56859)
jet ski trailer...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
