50 hour greasing
/ 50 hour greasing #11
My LS dealer specifically warned me about “ over greasing “ the axle pivot. He said a lot of owners over pressurize and blow the seal in the axle. He said
“ just a couple of pumps “ is more than enough if you do it each time you grease the rest. You will not see any grease oozing out like other zerks / pivots. I am just relaying what I was told...
Where does the old grease go?
/ 50 hour greasing #13
Apparently, it will ooze out when it pivots. I am sure if you pump enough in, it will ooze. He just warned not to over grease the joint. I have not looked at the parts breakdown to see what he was talking about.
/ 50 hour greasing #14
If I have the time to grease consider me lucky. Certainly don't have the time suspend things in the air to grease them.
You can use your front loader to take the weight off of the front axle. As long as you don't take off the front tires (or lay under them) you can grease the pivot without too much worry. Just stay out of the way of the wheels in case of a hydraulic failure.
/ 50 hour greasing #15
I usually grease until I hear the air pop. That usually means all the air is out and full of grease.
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
2006 International 4300 Altec LRV58 58ft Forestry Bucket Truck (A61568)
2006 International...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
