50 hour greasing
/ 50 hour greasing #1
AKcold
Member
LS XR3140HC
I have a XR3140H coming up on 50 hr and the manual says to grease front axle nipple "the appropriate amount". Curious what the appropriate amount is :)
/ 50 hour greasing #2
:confused3: Until it starts to come out somewhere else?
:laughing:
(Honestly, just give it two or three 'pumps' and then move on to the next one)
/ 50 hour greasing #3
Yeah it’s not very clear in the manual. I have the same tractor pretty much and I grease it every time I grease it the same as rest of the grease fittings. I figure a little extra is better than not enough.
/ 50 hour greasing #4
I'd pump it 3-4 times and you should hear or see old grease being pushed out. That is usually my cue to stop.
/ 50 hour greasing #5
There are mystery lube points. The blade spindles on my Woods PRD 7200 RFM for example. For some reason I came up with twenty pumps on my pneumatic grease gun and then later on twenty pumps on my Lincoln Powerluber. Woods says to lube the spindles every 8 hours but I lube about every 24-32 hours. This PRD 7200 now is now 13 years old and has about 1200 hours on it. Original spindles and original belt.
/ 50 hour greasing #6
One thing I always do when greasing that front axle pivot is to suspend the axle by lifting it off the ground with your loader or with a jack to the frame if no loader . This based on the fact grease always takes the path of least resistance by suspending the axle your releaving the load on the area it is needed and you’re grease will go there.
/ 50 hour greasing #7
^^^yes, me too. Same with old trucks/tractors with king pins.
/ 50 hour greasing #8
If I have the time to grease consider me lucky. Certainly don't have the time suspend things in the air to grease them.
/ 50 hour greasing #9
My LS dealer specifically warned me about “ over greasing “ the axle pivot. He said a lot of owners over pressurize and blow the seal in the axle. He said
“ just a couple of pumps “ is more than enough if you do it each time you grease the rest. You will not see any grease oozing out like other zerks / pivots. I am just relaying what I was told...
/ 50 hour greasing #10
I usually give 3 or 4 pumps or stop earlier if it comes out. Jus make sure your gun is pumping grease.
Ralph
/ 50 hour greasing #11
Where does the old grease go?
/ 50 hour greasing #13
Apparently, it will ooze out when it pivots. I am sure if you pump enough in, it will ooze. He just warned not to over grease the joint. I have not looked at the parts breakdown to see what he was talking about.
/ 50 hour greasing #14
You can use your front loader to take the weight off of the front axle. As long as you don't take off the front tires (or lay under them) you can grease the pivot without too much worry. Just stay out of the way of the wheels in case of a hydraulic failure.
/ 50 hour greasing #15
I usually grease until I hear the air pop. That usually means all the air is out and full of grease.
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2022 EZ-GO ELITE...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
