50" deck, good or bad??
/ 50" deck, good or bad?? #1
Brockwaykid
Granville NY
John Deere 317 (KT17 SII)
Havent really looked at the deck yet, once i get this tractor done, then its coming out. I found a V Belt for it amd searched the number, which comes up for a 50" deck. Not sure if it is a 50 but if it is, are they good decks? What are the pros and cons on them? Just want a general idea of what i might be getting into.....
Thanks
/ 50" deck, good or bad?? #2
Is this connected to some other thread? Not sure the question?
Yeah, Its connected to my build thread, but i havent looked at the deck to confirm anything. My question is, are 50" decks good or bad?
/ 50" deck, good or bad?? #5
Not sure what model of 50" deck you refer to but I have an '89 JD 318 with the 50" deck. After about 700 mowing hours I had to pay for 3 new spindle bearings, the OEM ones AND the replacments did not have grease fittings which is why the OEM's wore out quicker than they should have. Other than that, my deck served me well.
/ 50" deck, good or bad?? #6
I just helped my neighbor rebuild his and its one of the heaviest built decks I have seen other than my Kubota.
Definetly worth rebuilding if needed.
/ 50" deck, good or bad?? #7
I have a 50" on my 316. Great deck. One thing I would do though, is put the speed up pulley on it to get those blades turning a little faster.
I don't understand the grease fitting deal. These bearings are sealed. They don't need grease fittings. My spindles never had any grease fittings.
Normally these bearings have a 500 hour life span,so anything over that is a big bonus. I didn't have to change mine until 980 hours.:thumbsup:
Greg
/ 50" deck, good or bad?? #8
Greg
My 4210 7-Iron deck HAS grease fittings and is still mowing strong at at least 750 hours of operation. It cost me about $140 parts and labor to get new bearings put on my 50 inch deck and they would have lasted MUCH longer had they had grease fittings.
/ 50" deck, good or bad?? #9
Greg
I agree ^^ I have the 50 on my 318...its fine when the grass isnt that high or thick...but once you get into some high stuff it doesnt cut so nice...even with the blades sharp as a razor and running WOT.
/ 50" deck, good or bad?? #10
Not talking about a 7-Iron. It's an old 50" deck off a 300 series right? How long do you want it to last anyway. 700 hours is pretty darn good IMO.:) Like I stated earlier I didn't have to do anything until after almost 1000 hours, AND NO GREASE FITTINGS.:)
Greg
Greg
Well, Once I get the thing out to work on it I will know for sure if it is a 50. I think he might have got the wrong Vbelt, and the deck is a 48.....:confused: Could be a possibility.:confused2: I should get it out in a few weeks.
/ 50" deck, good or bad?? #12
Brockwaykid
Just curious...are you a kid, or a kid when it comes to mowers?
Certainly no offense meant.
beenthere said:
Brockwaykid
Haha Im 14, just a name I use on a few other sites.
213141 (A64276)
213141 (A64276)
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
John Deere 15' PT Batwing Mower (A64126)
John Deere 15' PT...
2022 EZ-GO ELITE...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
