Rotary Cutter 5 ft Howse cutter gear box smooth input shaft
   / 5 ft Howse cutter gear box smooth input shaft #11
Does the shaft on the gearbox turn with the shaft or does it seem to stay put? It sounds like shear bolt missing or output shaft might have worn splines.
   / 5 ft Howse cutter gear box smooth input shaft #12
Im saying the shaft that runs from the tractor PTO to the Mower gearbox spinns... but the blades do not move
Tks for the reply
You sheared the shear bolt.
MY reply was to the OP of the thread.
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A56858)
2007 Mitsubishi...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
Yard Machines Tiller (A55973)
Yard Machines...
2019 Harley Davidson (A56859)
2019 Harley...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
