5.5 K standalone generator and synthetic oil ?
   / 5.5 K standalone generator and synthetic oil ? #1
sailorman
Platinum Member
Southeast La.
Kubota 2320
Any reason why I shouldn 't use synthetic oil in the engine ( Briggs & Stratton ) ? Manual says nithing about it .
   / 5.5 K standalone generator and synthetic oil ? #2
Is it new? If so, you could use synthetics. If older, you might need an oil containing zinc compounds. Amsoil sells a synthetic with a zinc compound which I used in my forty year ols B&S with good results. Older engines need zinc compounds to lubricate valve stems, etc. Diesel oils typically contain zinc compounds.
Not more than 7 years old if that much . Where would you draw the line on old ?
   / 5.5 K standalone generator and synthetic oil ? #4
I switched all my small engines including gen to synthetic. About two years ago no problems to date
Thanks for the replies guys . Thought for a while I was on my own .
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
Cat TH407C Telehandler (A51039)
Cat TH407C...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
