5.5 K standalone generator and synthetic oil ?
   / 5.5 K standalone generator and synthetic oil ? #1
sailorman
Southeast La.
Kubota 2320
Any reason why I shouldn 't use synthetic oil in the engine ( Briggs & Stratton ) ? Manual says nithing about it .
   / 5.5 K standalone generator and synthetic oil ? #2
Is it new? If so, you could use synthetics. If older, you might need an oil containing zinc compounds. Amsoil sells a synthetic with a zinc compound which I used in my forty year ols B&S with good results. Older engines need zinc compounds to lubricate valve stems, etc. Diesel oils typically contain zinc compounds.
Not more than 7 years old if that much . Where would you draw the line on old ?
   / 5.5 K standalone generator and synthetic oil ? #4
I switched all my small engines including gen to synthetic. About two years ago no problems to date
Thanks for the replies guys . Thought for a while I was on my own .
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
377780 (A48837)
377780 (A48837)
