4x20 cabin air filter
   / 4x20 cabin air filter #1
JB Farm
Has anyone found an aftermarket filter to use as a cab air filter? If so would you share details as to where to get them? It would be nice to find a cheaper option, that filter costs way more than it should.
Thanks
Brian
   / 4x20 cabin air filter #2
Just went thru this with my 3720, no aftermarket cabin filters yet. But don't hold your breath assuming that aftermarket will be cheaper. I also needed an outer engine air filter; NAPA quoted me $41 (outer only), John Deere gets $31. So I'm picking up both filters at the JD dealer today. This isn't a one-off either. I needed a mower deck belt for a JD lawn tractor, got one from a local parts vendor. Chewed that sucker up in a matter of minutes. Went to JD, got a Kevlar-reinforced belt for less money than I had just spent on the one that had just self-destructed. Still had that belt on the deck when I sold the mower a few years later.
//greg//
   / 4x20 cabin air filter #3
I just blew my factory filter out with compressed air. Good as new. I do it once every 2 months. You get yours wet or something and now its ruined?
   / 4x20 cabin air filter #4
Isn't that what the book says? Blow it out, don't replace it. Nice for a change when "replace" isn't the norm.
   / 4x20 cabin air filter #5
I need to replace mine too, but four years is longer than I expected to get out of it.
   / 4x20 cabin air filter #6
When I am raking hay or mowing up some nasty stuff - I have to clean it every hour.
I go thru multiple filters in a year. I have actually had the filter fail and pull apart.
D.
   / 4x20 cabin air filter #7
D.
I'm sure your probably exaggerating a tad just to make a point but if that were true that its so bad you have to clean a cabin air filter every hour, you would have to do the same for the engine air filter and your radiator fins. Your machine would be a nightmare. Working in mass e excavation I have been in some disaster situations but can still get a full week in before cleaning anything. Just saying, you must be exaggerating a bit
   / 4x20 cabin air filter #8
If you run a 4520 cab a full week raking hay or mowing this dirty stuff - it will burn up period. The reality it can't go a whole day. The engine filter is a much better design. Do need to wipe off the grill often. Radiator blown out at least once a day.
I am not making this stuff up.
The cabin air filter design is crap.
Exactly the reason I can't wait for my 5093e to show up to replace it.
D.
   / 4x20 cabin air filter #9
New filter run one day on my 4520. Mx6 shredding real low cleaning up after clearing stumps. Hot summer day dry. Lots of dirt.
You be the judge.
D .
   / 4x20 cabin air filter #10
You be the judge.
D .
this is after a week or an hour...?
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
Roller (A52377)
Roller (A52377)
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
1983 Case 580D (A47477)
1983 Case 580D...
